SonnyJ Posted January 5, 2010 Share Posted January 5, 2010 Is there anything preventing a herk from flying normal missions if one aux tank is out and the other is full and they are abiding by fuel unbalance limits listed in the FM? Quote Link to comment Share on other sites More sharing options...
WxFE Posted January 5, 2010 Share Posted January 5, 2010 Is there anything preventing a herk from flying normal missions if one aux tank is out and the other is full and they are abiding by fuel unbalance limits listed in the FM? Nope, not unless there's been a change since I last flew in August 2005. That's the one sets of tanks (other than Bensons) that you can fly with one full and one empty. Quote Link to comment Share on other sites More sharing options...
Muff Millen Posted January 6, 2010 Share Posted January 6, 2010 Right...no restriction. Muff Quote Link to comment Share on other sites More sharing options...
ldschmidt29 Posted January 6, 2010 Share Posted January 6, 2010 Aux tanks are basically cargo weight, the are so close to CG that it won't throw off you weight and balance. Quote Link to comment Share on other sites More sharing options...
C130CC Posted January 18, 2010 Share Posted January 18, 2010 I concur. Quote Link to comment Share on other sites More sharing options...
SEFEGeorge Posted January 18, 2010 Share Posted January 18, 2010 Aux tanks are basically cargo weight, the are so close to CG that it won't throw off you weight and balance. Is that so close to CG or so close to centerline that they won't affect the wing load balance? Quote Link to comment Share on other sites More sharing options...
Skip Davenport Posted January 18, 2010 Share Posted January 18, 2010 It's been a long time since I have flown a Herk. BUT my memory says like everyone else the Aux tanks have no effect on weather one is full or one empty Quote Link to comment Share on other sites More sharing options...
ldschmidt29 Posted January 18, 2010 Share Posted January 18, 2010 centerline! thanks for catching that... Quote Link to comment Share on other sites More sharing options...
Old Fella Posted January 20, 2010 Share Posted January 20, 2010 Is there anything preventing a herk from flying normal missions if one aux tank is out and the other is full and they are abiding by fuel unbalance limits listed in the FM? Just a question. Why would you want to fly with one aux tank full and the other empty. Are you asking about commencing a mission in this condition or continuing? Quote Link to comment Share on other sites More sharing options...
DC10FE Posted January 20, 2010 Share Posted January 20, 2010 Just a question. Why would you want to fly with one aux tank full and the other empty. Are you asking about commencing a mission in this condition or continuing? Had to do it a few times at Transafrik for either a leak or an inop boost pump. Lose $$$ if it sits on the ground waiting for repair. Don R. Quote Link to comment Share on other sites More sharing options...
C130CC Posted January 20, 2010 Share Posted January 20, 2010 Just a question. Why would you want to fly with one aux tank full and the other empty. Are you asking about commencing a mission in this condition or continuing? This is not uncommon at all. Main tanks on the other hand are a different story, but aux tanks are just that, auxiliary. Quote Link to comment Share on other sites More sharing options...
AMPTestFE Posted January 20, 2010 Share Posted January 20, 2010 I wouldn't have a single issue with flying like this for any reason. Quote Link to comment Share on other sites More sharing options...
SEFEGeorge Posted January 20, 2010 Share Posted January 20, 2010 Is there anything preventing a herk from flying normal missions if one aux tank is out and the other is full and they are abiding by fuel unbalance limits listed in the FM? I've flown missions like this, both operational, mission support, and pilot pro. The only in was given any real consideration was how long the mission was. Wouldn't want to fly a 10 hr overwater nav out of LRF this way, or a trip from EDF to Hickam, out an actual recovery mission out of Hickam. There could be any number of things to fly this way - tank leak, inop boost pump, fuel quantity problems (even though the 1 full-1 empty doesn't need any consideration with fuel qty problems, just use the "dip stick"). Quote Link to comment Share on other sites More sharing options...
Ronc Posted January 21, 2010 Share Posted January 21, 2010 I've flown missions like this, both operational, mission support, and pilot pro. The only in was given any real consideration was how long the mission was. Wouldn't want to fly a 10 hr overwater nav out of LRF this way, or a trip from EDF to Hickam, out an actual recovery mission out of Hickam. There could be any number of things to fly this way - tank leak, inop boost pump, fuel quantity problems (even though the 1 full-1 empty doesn't need any consideration with fuel qty problems, just use the "dip stick"). I read enough of SEFEGeorges report, he knows the aux tank can't be dipped in the conventional way and you have to use the fuel tank gauge on the bottom of the wing Quote Link to comment Share on other sites More sharing options...
WoodysDiscoPalace Posted January 22, 2010 Share Posted January 22, 2010 I agree - mostly because of leaks in the aux (bladder) cells. There was a period of time where it seemed like we had a aux cell leak on almost every aircraft. Standard fuel load at the time was 36K for a trash hauler, and config was either 8-7-3, or 7-6-5 (outboard to inboard) keeping as much fuel in the outer wings as possible, for as long as possible (to lessen wing stress). The externals were not used unless necessary for a higher fuel load. If you had one aux cell out, you would try to squeeze 8.5 in the outbd's, 7.5 in the inbd's, and 5 in one aux (and hope the aircraft wouldn't start venting before take-off). 40K was standard on HC/MC's, but you had the Benson tanks so no worries even if both aux cells were leaking. Quote Link to comment Share on other sites More sharing options...
