rsd653 Posted August 11, 2011 Share Posted August 11, 2011 Starting tit high more than 850'c of T56-A-7b Eng, ie, we can't go upto 60%rpm just 40%rpm we get 850'c tit and its not cut back tit will go up and up . We already chanch TD valve adjust Fcu,TD AMPS clalibared, blade angle ck its ok. thermocopple and harnes chanch, bleed valve ck its ok. Fuel nozzle chanch,try to start the eng in null position but problem is same. Can anybody help me quickly pl. After fcu change tit was 850 i e more than 20 above from normal rating. "Thanks to all we just over come the problem. Quote Link to comment Share on other sites More sharing options...
NATOPS1 Posted August 11, 2011 Share Posted August 11, 2011 Check and make sure you compressor bleed valves (all of them) are open and your Prop blade angle is correct. Quote Link to comment Share on other sites More sharing options...
pjvr99 Posted August 11, 2011 Share Posted August 11, 2011 starter control valve not opening fully, bleed air shut off valve not opening fully, starter turbine damaged, compressor worn out/FOD'ed, cracked bleed air duct, blown bleed duct gasket, speed sensitive valve porting air to bleed valves below 94%, TD amp driving TD valve to PUT condition Quote Link to comment Share on other sites More sharing options...
tusker Posted August 11, 2011 Share Posted August 11, 2011 let us assume the starting time is ok!....props blade angle is in ground idle range ok...You've tried it in null!!........rigging is ok!!......could have to deal with an FCU change..What else could it be. ......................the bad John.......................................................I think if I recall.....had that kind of problem many sun arounds!!............Cheers to you guys!! Quote Link to comment Share on other sites More sharing options...
victorp1 Posted August 12, 2011 Share Posted August 12, 2011 I agree with NATOPS1 about the acceleration bleed valves. Disconnect the high pressure out line at the speed sensitive valve which goes to the acceleration bleed valves and see if it starts OK. I had a bad speed sensitive valve one time which would close the valves at 45% and the TIT would increase rapidly. After shutdown a visual of the acceleration bleed valves revealed they were open because when the RPM droped below 45%. Quote Link to comment Share on other sites More sharing options...
tusker Posted August 12, 2011 Share Posted August 12, 2011 Does it mean the herc is grounded because you can't get the eng started within the limits allowed!! I stick with the FCU change. Let me know!!.....You've changed a TD valve so......get this FCU off!!! If I'm wrong, you can kick my ass!!LOL!!!..........John Quote Link to comment Share on other sites More sharing options...
NATOPS1 Posted August 12, 2011 Share Posted August 12, 2011 Well, lets see FCU change or something 100000000% easier... HUM.... There are so many things that can cause this, so to not do all the easy (cheaper) things first is not the best way to go about it. It looks like rsd653 has done most of them so... rsd653 when you say "Starting tit high more than 850'c" how high? Have you tried to use high pressure air from an engine or just you GTC? Pj brings up a good point the starter may turn the prop and engine but may bog down due to failure or the starter control valve may be "regulating" the air to the starter at a lower pressure. When you start the engine how "low" does the air pressure go? At 16% what is the air pressure reading? 22 psi + I would guess as you continue the start until the overtemp. What RPM do you get to befor the temp goes up? 30 40 or 60%? Quote Link to comment Share on other sites More sharing options...
Lkuest Posted August 13, 2011 Share Posted August 13, 2011 I agree with pjvr99 and NATOPS. Victor, never heard of a speed valve fail that way, so good to know! Quote Link to comment Share on other sites More sharing options...
tusker Posted August 14, 2011 Share Posted August 14, 2011 Yes sir Guys!!!!.......So!!!.....what's the score!...Is that machine still on the ground!! So.....RSD653 what's the score!!.......Us old men want to know!! Go for it!! Tell us!! Quote Link to comment Share on other sites More sharing options...
tusker Posted August 14, 2011 Share Posted August 14, 2011 .......are we or should I say ..............are they lining up for an engine change!!!!!........if we talk about engine FOD. Now!!! We do not have any more feed back! ..............................."Starting tit high more than 850'c of T56-A-7b Eng." So!!.......did you get the engine started !!! .................what are the readings!!!!! My C-130 run up book is at the job right now!!! But of course it's only a Forum!!!........................why should I worry!!!..................Cheers to you guys................Réj. Quote Link to comment Share on other sites More sharing options...
jrkaegi Posted August 14, 2011 Share Posted August 14, 2011 .......are we or should I say ..............are they lining up for an engine change!!!!!........if we talk about engine FOD. Now!!! We do not have any more feed back! ..............................."Starting tit high more than 850'c of T56-A-7b Eng." So!!.......did you get the engine started !!! .................what are the readings!!!!! My C-130 run up book is at the job right now!!! But of course it's only a Forum!!!........................why should I worry!!!..................Cheers to you guys................Réj. You didn't say if you adjusted the Null, to a lower setting. Quote Link to comment Share on other sites More sharing options...
tusker Posted August 14, 2011 Share Posted August 14, 2011 Good day jrkaégi!!!. No I never said it because I do not work on Hercs anymore( for now) . I used to be in CAF Trenton. Now I work on aircrafts somewhere else. So!!! to make a long story short!!...........the guy didn't mention any adjusment on the TD valve. Maybe he did. Only "God" knows!!!!! All I feel is that they have an aircraft nailed to the ground because of a Starting temp prob. So!!!...do we adjust the null!!.......If we do and it do not check serviceable........we do what!!...............Change FCU!!..........If I'm wrong like I said................just come down and kick my ass............very gently of course!!!!!....LOL!!! Quote Link to comment Share on other sites More sharing options...
tusker Posted August 15, 2011 Share Posted August 15, 2011 So!!.........what's the score!!! Is it flying or not.......Like the guy said:......"Kick the tires and light up the fires"!!!...............I think they just might have enough fire in the turbine as is!!!!!!...for now!!!............Just blow it out!!!....I'm just a beast!!! Quote Link to comment Share on other sites More sharing options...
tusker Posted August 15, 2011 Share Posted August 15, 2011 This bird's got to be serviceable Quote Link to comment Share on other sites More sharing options...
tusker Posted August 17, 2011 Share Posted August 17, 2011 This Hercules has been nailed for 6 days now!!! Quote Link to comment Share on other sites More sharing options...
tusker Posted August 18, 2011 Share Posted August 18, 2011 no news from the guy with the overtemp on start!!!!!..........I think he got thunderstrucked!!!!!!!!!!!!! unless the guy is on days off!! Quote Link to comment Share on other sites More sharing options...
tusker Posted August 20, 2011 Share Posted August 20, 2011 Do you think it is useless as tits on a bull to care about that kind of request!.We do not get any feed back!! I must be dumb to beleive ..................oh wel!! Quote Link to comment Share on other sites More sharing options...
tusker Posted August 20, 2011 Share Posted August 20, 2011 The guy must have found the problem!!.....Good for him!!..........who knows!!........he might be out of employment now!! What Am I saying!!..I am so foolish sometimes!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!LOL!!! Quote Link to comment Share on other sites More sharing options...
tusker Posted August 29, 2011 Share Posted August 29, 2011 Guys!!!....I beleive that Herc ain't flyin' yet!! Let's do some brain storming !! Do you think that a boroscope of the engine would help!! Quote Link to comment Share on other sites More sharing options...
RZHill Posted August 30, 2011 Share Posted August 30, 2011 I think "it's Time" Quote Link to comment Share on other sites More sharing options...
Weasel Pilot Posted August 30, 2011 Share Posted August 30, 2011 Think you scared him off! Quote Link to comment Share on other sites More sharing options...
tusker Posted August 31, 2011 Share Posted August 31, 2011 ..good day guys!!....So finally, the guy changed the FCU and the coordinator......and adjusted the fuel on FCU. I beleive that coordinator change wasn't necessary but!!!....So,.....what do you think!.............just to chew the fat!! Quote Link to comment Share on other sites More sharing options...
Mcmuffin07 Posted October 9, 2011 Share Posted October 9, 2011 Haha i think i'm a little late on this one, but i'd measure the bellows. maybe ruptured, 850 TIT at 40% on start sounds like ruptured bellows to me. you could change the bellows individually and save about $70K but personally...i'd rather change the FCU haha Quote Link to comment Share on other sites More sharing options...
tusker Posted October 9, 2011 Share Posted October 9, 2011 I didn't know you could change bellows.!...........Do you work in a shop!! Quote Link to comment Share on other sites More sharing options...
Jim Denney Posted November 4, 2011 Share Posted November 4, 2011 Could it the 3.5 bleed air check valve, top right aft on engine, be stuck partially open reducing the air pressure to the starter? I worked civillan Herks for 6 years and had about 4 problems with that ck valve. Either stuck partially open, or all the way open. Not all acceleration bleed valves open for the start? The ones on the bottom are famous for sticking due to prop/engine leaks. Quote Link to comment Share on other sites More sharing options...
